01-19-2016 06:55 PM
I am trying to install the NI-488.2 drivers provided here, on a fresh install of CentOS 7 (centOS 7 seems to be available for x86_64 architectures only).
First error I get during the installation is the following :
/lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
So I guess this is because of some missing 32 bits library, I look on the web and end up doing :
yum -y install glibc.i686
The previous error seems fixed but then I get this one :
Warning :nikali post installation failed! /tmp/nikaliPostInstall.log follows: nikal: ERROR: Error locating kernel sources for the requested kernel version (3.10.0-327.el7.x86_64).
which is weird, because the requested kernel version seems to match the one I get with uname -a. I tried to install the kernel-devel package but does not solve anything.
I tried to reboot and execute /usr/local/bin/gpibexplorer just in case and encountered a problem with libgcc_s.so.1 and libgl, which I installed.
I also ran updateNIDrivers which seemed to succeed and rebooted.
Finally, running gpibexplorer seems to work for a bit (a window appears) and then crashes instantly with the following error message :
libnipalu.so failed to initialize
I did not find a solution to fix this last issue yet.
Thanks for your help.
01-19-2016 07:19 PM
Ok, so I already have some updates on this.
I tried to run all the binaries and installed the missing libraries each time there was one.
Then I uninstalled the driver and installed it : it seems to be successful this time.
However gpibtsw stills tells me that my driver installation is not correct and that I should reinstall it.
And gpibexplorer still fails with the same error as stated in my previous message.
Thanks again.
01-21-2016 07:24 AM
Thanx for the update.
In order to use gpibtsw you have to be a root user. Are you?
source http://ae.natinst.com/public.nsf/web/searchinternal/8311fff18b5308ed86256c0200653b3b?OpenDocument
