I've used the same module you must be trying to load, tnt4882.o, on my
PCI-GPIB+ card. Used it with LabVIEW without too many problems. Never
tried it with the PCMCIA-GPIB card.
You're probably better off posting to the Linux-GPIB mailing list (not
that you shouldn't post here). Mr. Hess and the other developers are very
nice about providing support. When you do post there, ensure you mention
at least the following:
1) output from 'dmesg' after loading the module
2) modifications to your gpib.conf file
3) results of running the administration program 'gpib_config'
4) I forget what the packaged test interface is called but it allows
you run ibread, ibwrite, etc functions. See if that works.
5) all relevant SW versions you're
using
There could be some pcmcia config files to alter but I'm such a newbie to
that stuff. Well, I just looked at the LG ML and there was a recent post:
http://sourceforge.net/mailarchive/forum.php?thread_id=4854735&forum_id=2853
"run the configure script with --enable-pcmcia"
