We are trying to isolate an apparent 100-200ms latency from data xmitted to NI485/4 and program response. Using win2k with virtually no CPU being used. Code appears to be well written and has system priority. We have Intel D845GBV2 board and have three PCI cards, NI485/4, Data xlation 3153, and I/O card.
I suspect PCI problems. The NI 485/4 works fine except for latency and installation shows no problems except for memory address conflict between each of the four ports, however I suspect this is not a problem as all four ports are on the same card.
Any suggestions?
