Hi Victor,
if you want to get the image of your device, the data will be send byte to byte through the GPIB connection.
If you know how to read the image with the ibwrt and ibread, you can easily use the VISA functions for communicating via GPIB.
Just use the "Open", "Read" and "Close" VISA functions.
With the openVISA you configure your Interface and with the read, you can read all the data from the interface buffer until the number of bytes to read was reached, timeout error occurs or the "End" character was sent.
If you know the exactly size of the images, set the numbers to read to this size and you get an string as output. The string is equal to an array of U8-values (function for transferring string to [U8] can be found in the String pa
lette..).
Then you can use the standard VIs for working with the image data.....
Stefan K.
NI Germany
(SRQ 196106)
