I've installed my PCI-GPIB on a system running windows xp, it was on a system running windows 98 and worked correctly. I am using the card to capture data from a Magtrol Dynomometer Controller. I've run the software and driver updates from NI website. Also, when I am in the MAX software and communicate with my instrument manually I can read correctly from the instrument. What is happening is that when I try to write and read from the magtrol controller the data stream is not ending(getting the cr-lf?). In the magtrol installation instructions it says:" GETTINGSTARTED
1. From the Windows taskbar, click Start, then point to Settings and click Control Panel.
2. Double-click System. This will bring up the System
Properties dialog box.
3. Click the Device Manager tab.
4. Using the right mouse button, click (right-click) National Instruments GPIB Interfaces.
5. Click Properties.
6. Click the Device Templates tab. See Figure 2�4 System Properties & GPIB Interfaces
Properties.
7. Scroll down Device Name list until DEV9 is reached.
8. Click DEV9.
9. Set DEV attributes to the following:
a. Under Termination Methods, select the Terminate Read on EOS check box.
b. Change EOS Byte to �10�.
c. Select the Readdress check box."
The problem is when I right-click on National Instruments GPIB interfaces I get a dialog box with a tab that says "General" and an empty page. I think my devices are probably not setup correctly because I haven't followed the magtrol instructions (this worked on the windows 98 setup). I am not sure how to fix this, Any help would be appreciated.
Thanks in advance,
Jennifer
