03-22-2005 09:08 AM
03-22-2005 09:20 AM
03-22-2005 09:50 AM
@Dennis Knutson wrote:
Need a bit more information from you.
1). Does the instrument show up in MAX when you do a scan for instruments?
2). Can you communicate with it in MAX?
3). Who makes the laser diode driver?
4). Is there a LabVIEW instrument driver available for it?
5). Are you using VISA Read/Write or GPIB Read/Write?
6). What error codes or messages are you getting?
Questions 1 and 2 are the most important. If nothing shows in MAX, then you won't be able to communicate. If sending commands in MAX doesn't work, you may have the syntax incorrect. Once you can get communication in MAX to work, you should try the shipping example called LabVIEW<->GPIB or the Instrument I/O Assistant.
03-22-2005 11:24 AM
03-24-2005 01:04 PM
03-24-2005 01:39 PM
