The first thing I wanted to verify with you is what GPIB board you have. You will only be able to use the GPIB Analyzer with a GPIB+ board. These boards can be found at the following link.
http://sine.ni.com/apps/we/nioc.vp?cid=12461〈=US
Also, if you do have one of these interfaces, then I need to request more information, such as the driver version and OS you are using. Also, are able to communicate with your instrument successfully in MAX?
Hope this helps!
Steven B.
Applications Engineering
