NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Knight of NI
Dennis_Knutson
Re: GPIB-USB and Matlab
What is an 89090A. A search of Agilent's site did not return any results.
Can you attach the programming manual or something that explains the command you are sending? Typically, a query is terminated with a ? so the read timeout would be expected, though the fact that it does not support *IDN? could mean that the instrument has no standard programming interface at all. You obviously can run only queries that are listed in the manual.
Member
Tnguyen628
Knight of NI
Dennis_Knutson
Okay, I searched test and measurement.
From your screen shot, it does not look like you are sending the correct terminator. By default, only EOI is sent.
Member
Tnguyen628
So what should I do? What am I supposed to send?
Knight of NI
Dennis_Knutson
Append a LF or CR/LF as described in the manual.
Member
Tnguyen628
Sorry I am not familiar with the abbreviations ... what does that mean??? can you point me to the page of the manual?
Member
Tnguyen628
ok you mean this? What am I supposed to do with it?
I typed in "REM ON" and still gives me the error
Parameter
[ on | off ]
Reply
[ on | off ] <CR> <LF and EOI>
Description
This instruction is used to switch remote mode on and off. With REM ON the
temperature control unit is set in a remote mode. In this remote state the
keyboard is disabled for all inputs (only the UP , DOWN , and CLEAR  keys are
accepted). The ENTER  key is only accepted within the remote function context,
that is to change the display for system and main functions and to reset
remote to off. However, the function REMOTE ON, which is selected, can be used
to reset to REMOTE OFF instead of using the REM OFF command, (see also
“Remote Mode” on page 88).
Reply Description
The REM instruction without parameters returns a string which represents the
current state of the temperature control unit:
on = remote mode
off = normal mode
See “CSM – Agilent ChemStation Mode” on page 98 for interpreting the reply
when using the CSM command.
Knight of NI
Dennis_Knutson
In MAX, use \r and \n for carriage return and line feed.
Member
Tnguyen628
Where am I supposed to edit the codes? I still don't understand...
I'm still referring to this error btw:
Knight of NI
Dennis_Knutson
I use VISA but I believe the 488 tool works the same way - simply type in the control characters after the command string.
You also have the EOS configuration there and on the GPIB properties page.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
