Reply
GPIB-USB and Matlab
Re: GPIB-USB and Matlab
What is an 89090A. A search of Agilent's site did not return any results.
Can you attach the programming manual or something that explains the command you are sending? Typically, a query is terminated with a ? so the read timeout would be expected, though the fact that it does not support *IDN? could mean that the instrument has no standard programming interface at all. You obviously can run only queries that are listed in the manual.
Message 21 of 51 (1,117 Views)
Reply
Message 22 of 51 (1,112 Views)
Reply
Okay, I searched test and measurement.
From your screen shot, it does not look like you are sending the correct terminator. By default, only EOI is sent.
Message 23 of 51 (1,110 Views)
Reply
So what should I do? What am I supposed to send?
Message 24 of 51 (1,107 Views)
Reply
Append a LF or CR/LF as described in the manual.
Message 25 of 51 (1,096 Views)
Reply
Sorry I am not familiar with the abbreviations ... what does that mean??? can you point me to the page of the manual?
Message 26 of 51 (1,092 Views)
Reply
ok you mean this? What am I supposed to do with it?
I typed in "REM ON" and still gives me the error
Parameter
[ on | off ]
Reply
[ on | off ] <CR> <LF and EOI>
Description
This instruction is used to switch remote mode on and off. With REM ON the
temperature control unit is set in a remote mode. In this remote state the
keyboard is disabled for all inputs (only the UP , DOWN , and CLEAR  keys are
accepted). The ENTER  key is only accepted within the remote function context,
that is to change the display for system and main functions and to reset
remote to off. However, the function REMOTE ON, which is selected, can be used
to reset to REMOTE OFF instead of using the REM OFF command, (see also
“Remote Mode” on page 88).
Reply Description
The REM instruction without parameters returns a string which represents the
current state of the temperature control unit:
on = remote mode
off = normal mode
See “CSM – Agilent ChemStation Mode” on page 98 for interpreting the reply
when using the CSM command.
Message 27 of 51 (1,087 Views)
Reply
In MAX, use \r and \n for carriage return and line feed.
Message 28 of 51 (1,083 Views)
Reply
Highlighted
Where am I supposed to edit the codes? I still don't understand...
I'm still referring to this error btw:
Message 29 of 51 (1,079 Views)
Reply
I use VISA but I believe the 488 tool works the same way - simply type in the control characters after the command string.
You also have the EOS configuration there and on the GPIB properties page.
Message 30 of 51 (1,076 Views)
Reply
