02-14-2012 02:31 PM
What is an 89090A. A search of Agilent's site did not return any results.
Can you attach the programming manual or something that explains the command you are sending? Typically, a query is terminated with a ? so the read timeout would be expected, though the fact that it does not support *IDN? could mean that the instrument has no standard programming interface at all. You obviously can run only queries that are listed in the manual.
02-14-2012 03:01 PM
The manual is this one:
http://www.chem.agilent.com/Library/usermanuals/Public/89090-90003_ebook.pdf
On the device it said Agilent 89090A on it.
This one:
http://www.chem.agilent.com/en-us/store/_layouts/agilent/commerce/storesearchresults.aspx?sp=89090a
02-14-2012 03:12 PM
Okay, I searched test and measurement.
From your screen shot, it does not look like you are sending the correct terminator. By default, only EOI is sent.
02-14-2012 03:16 PM
So what should I do? What am I supposed to send?
02-15-2012 10:09 AM
Append a LF or CR/LF as described in the manual.
02-15-2012 11:11 AM
Sorry I am not familiar with the abbreviations ... what does that mean??? can you point me to the page of the manual?
02-15-2012 11:24 AM
ok you mean this? What am I supposed to do with it?
I typed in "REM ON" and still gives me the error
02-15-2012 11:35 AM
02-15-2012 11:55 AM
Where am I supposed to edit the codes? I still don't understand...
I'm still referring to this error btw:
02-15-2012 12:18 PM
I use VISA but I believe the 488 tool works the same way - simply type in the control characters after the command string.
You also have the EOS configuration there and on the GPIB properties page.
