09-30-2014 04:24 AM
I have NI GPIB interface, that is GPIB-USB. I have installed the GPIB-USB driver. I connect the GPIB-USB to the Hybrid Recorder 1300 Yokogawa. IN NI MAX GPIB-USB-HS is already there, but when I scan for instruments (HR 1300) , instrument is not shown. In connected instruments it shows Instruments not…
Do I need driver for HR 1300 also? I found ykhr130g driver for HR 1300 from NI. But it doesn’t respond with HR1300.
09-30-2014 06:26 AM
Is your instrument configured to talk over the GPIB? What address is it set to? Are you seeing any instrument when you do the scan for instruments?
09-30-2014 07:20 AM
The Yokogawa HR1300 is a 25-year old piece of test equipment. It will not respond to *IDN?
10-08-2014 10:30 AM
Hallo
THANKS FOR THE REPLY:
Ans: Yes I have set HR1300 using its usermanual section 1,5( setting mode address)
What address is it set to? : primary address set to 1
Yes I can see it : instrument :Insstrument0 . PAD:1, SAD:None Identification: the device did not respond to *IDN? Query
I think now my GPIB nad HR1300 is communicating with eachother. I found ykhr130g from NI for Labview. Its consists of number of .vi program. But none of them is working (attached) . As my understading to the program dataLogging.vi is used to measured online information from devide and write into DATAFILE.TXT file. But program dosent work . I am not very good in the programming. Could any one help it. I am not sure it work or not.
10-09-2014 03:13 AM - edited 10-09-2014 03:18 AM
Hello nijan,
do you know if your device should responde on *idn?, do you know other query for the device ?
http://digital.ni.com/public.nsf/allkb/5144DBBA272C2A48862578C000649B2E
There was the same problem
Best Regards
