You don't actually say what you did to correct the problem. Did you change the gpib-enet/100 to DHCP?
If so, how did your local network handle the host name? Mine kept rejecting it, until I "register" with the local DNS folks, who said that mode wasn't supported. Their suggestion was to have a static IP address, which they will assign. This will leave the DHCP option out.
I think the device should work in manual IP mode, as that would fit the majority of users, who would not have a network operations support to assign IP addresses dynamically, and have the device on the same sub-net as the computer, that is trying to talk to it. The sub-net being the inside of a router, isolated from the rest of the internet.
I ended up calling the
NI service people, who had a number of suggestions.
Right now, I'm still trying to pass the GPIB trouble shoot gpib interfaces sequentially verified part. Also I still fail in communcating with an instrument, via the interactive control.
Part of my problem is that I started with a crossover enet cable, so that the gpib-enet wasn't even on the ethernet, but I had no luck that way. The NI folks will work on that, and get back to me.
About help; If you go to the interactive control, and type help, this will bring up help in your default browser.
