NI Home
Cart Cart | Help
You are here:
Reply
Member
Ameer
GPIB Device doesnot respond to *IDN? QUERY
HELLO,
I Am trying to interface  my GPIB instrument with HOST computer through LabVIEW, unfortunately my GPIB instrument doesnot respond to *IDN? QUERY. Could not find out what is problem with this. Could anyone can help in this regard.
Ameer
Active Participant nyc
Active Participant
Re: GPIB Device doesnot respond to *IDN? QUERY
Are you sure the instrument should respond to a *IDN?
Does it say it does in the manual?
Member
Ameer
ya the GPIB instrument "doesnot" respond to *IDN? query
Active Participant
Huh? Care to rephrase your answer to my question.
Knight of NI
Dennis_Knutson
Ameer,
It seems you are a beginner with GPIB instruments. Not all instruments will respond to the *IDN? query. You failed to mention the make and model and that is vital information. Look in the programming manual to see whether *IDN? is listed. If it is not, then simply ignore the warning. If it is listed, then you can start to worry.
Member
mkossmann
Just one addtion: there are even some instruments ( like the agilent 603x powersupplies) which support two different sets of command languages. One set supports the*IDN? query but the other set not.
Active Participant
Makoto
If the product specification of your instrument says IEEE488.2-compliant (and optionally SCPI language compliant), the instrument must respond to an *IDN? query. Otherwise it may or may not understand the *IDN? query.
Member
Ameer
In my instrument manual nowhere is written about *IDN? query and anything related to it.
Member
Ameer
Am using HORIBA MEXA 9000 series vehicle exhast gas analyser. it is pre 1990s model. and CVS system.
Member
Ameer
My product specification is IEEE488 it uses ASCII 1978 model.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
