11-19-2014 07:28 PM
Once I got a USB adaptor and plugged it into the computer it worked. The computer recognized it. I recieved the software for it and an english manual so things should be looking up.
11-19-2014 08:01 PM
11-20-2014 07:23 AM
Clueless again.
I would hope the computer would recognize the USB-RS232 adapter.
The function generator is totally different issue.
Software for it? How is that going to be helpful?
11-21-2014 05:45 AM
Maybe the RS232 commands and it's parameters are noted in the manual.... and if not, a little reverse engineering by sniffing the RS232 port while using the software is an easy way to go 🙂
But peeking into a foreign language manual, I found parts that looks like a RS232 command description... so some simple VISA commands should do the job.
11-21-2014 08:51 AM
You may be able to figure out the foreign language manual, because you know what you are looking for.
I am not sure the same can be said of the OP.
I find it oddly coincidental that he has now obtainedthis so-called software and an English-language manual.
11-24-2014 01:14 PM
Here is the English manual with the command protocol and commands.
-AK2DM
