FGEN-SFP 1.3 cannot find NI Configuration Manager
I recently installed NI-FGEN 2.0 including FGEN-SFP 1.3. When I try to start the Soft Front Panel, I get a message saying that NI Configuration Manager cannot be found and that I need CM 1.0.0 or higher.
What is NI Configuration Manager and where do I get it?
(3,416 Views)
Joel,
When you installed NI-FGEN did you also install NI-DAQ? NI-DAQ is required for some of the base communication to the board. You can download and install NI-DAQ from:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C128D?opendocument&node=132060_US
Hope this helps.
Kevin R
(3,416 Views)
Yes, NI-DAQ 7.0 was installed before I installed NI-FGEN.
(3,416 Views)
I uninstalled my current NI-DAQ 7.0 installation and installed NI-DAQ 7.0.1 (I'm sure just reinstalling 7.0 would have worked too). Now it works fine. Thanks for the help.
(3,416 Views)
