I've a problem when I try to download the capture buffer from a spectrum analyzer with C++Builder and VISA.
If I do that with LABVIEW (with VISA read and write) everything is fine. Instead, with C I get extra bytes in
the stream. In particular whenever there is a '0A' in the stream I get also a '0D' before it. I'm using a GPIB-USB-B card from National. I know I could easily get rid of those extra bytes in my code, but I'd like a cleaner solution.
Does anybody know the difference between the following code and LABVIEW VISA read and write routines?
Is there some attributes I have to set in C which is automatically set in LABVIEW?
Thanks a lot in advance!!
Simone
ViSession defaultRM, vi;
viOpenDefaultRM (&defaultRM);
viOpen (defaultRM, "GPIB0::10::INSTR", VI_NULL,VI_NULL, &vi);
ViStatus err = viSetAttribute(vi, VI_ATTR_IO_PROT, VI_NORMAL);
ViUInt32 retCount;
err = viWrite(vi, "CGET?0,0\n", strlen("CGET?0,0\n"), &retCount);
ViByte* buffer = new ViByte[100000];
err = viRead(vi, (ViByte*)buffer, 100000, &retCount);
FILE *fp;
fp = fopen("data", "w");
fwrite (buffer, retCount, sizeof(ViByte), fp);
fclose(fp);
viClose(defaultRM);
viClose(vi);
delete []buffer;
