External DMM Not Communicating with LabVIEW Executables
I currently have a system of power supplies connected with GPIB and a Agilent E34405A DMM connected via USB.  The system works fine when I use the full Labview program, but when i make a executable and installler and put it on another machine I cannot get the DMM to communicate the power supplies work fine and so does my other equipment.  Any thoughts?
(4,588 Views)
check in the Max , whether the DMM is detected and query the Instrument ID.
(4,559 Views)
Is the DMM recognized in Windows device manager and the USBTMC  driver loaded on the target system ?
(4,541 Views)
The instrument shows up in NI MAX, I will try to query it today and let you know how it goes.
(4,527 Views)
Accepted by topic author Kody
If your LabVIEW program uses NI-VISA you will need to load NI-VISA Runtime on the target PC.
(4,477 Views)
I got the Executable working.  There was a sub vi I didn't know about looking for the insturment name from a text file that didn't exist and caused an issue.
(4,473 Views)
