08-13-2014 04:42 AM
I am trying to communicate with a USB HID device. I have already installed driver INF and successfully open it using VISA Test Panel. I can see the device under the MAX Devices & Interfaces.
I try to run LabVIEW 2003 example "USB RAW - Interrupt.vi".
I don't quite understand the example. Is it just receiving data from the device?
If I want to send HID data to the device, how can I do it? Anyone has any example?
08-13-2014 07:27 AM
08-13-2014 07:54 AM
08-13-2014 08:14 AM
What is your device, what kind of information can you send it and over which mode of transfer do you need to send it.
Please provide a link to the commnds specified for the device so that we know what you're talking about.
Shane
08-13-2014 11:02 AM
It is a customised LCD display with USB port. The USB is a HID device, there is complete Device/Configuration/Interface descriptors, and also the HID report descriptor. I am not exactly sure how to find out the mode of transfer from the descriptors.
Must I use VISA? I know how to do LabVIEW graphical programming (but not expert). As for LabVIEW for USB, I don't even know where or how to start.
Is there any example vi which I can follow?
08-13-2014 12:32 PM
08-13-2014 02:20 PM
Well then my question to you good sir is what on earth do you want to send to the device?
I suggest you read up on the USB spec (particularly Chapter 9) to be found HERE.
If that frightens you, stop using VISA RAW because it'll lead you nowhere.
08-13-2014 02:29 PM
08-14-2014 06:09 AM
I use hid.dll and managed to get it to work.. Too much trouble using MAX
