11-09-2012 12:53 PM
Not that long ago I connected an instrument that was not VXI compatible. Such an instrument does not show up in MAX with an automatic search.
Use the option 'manual entry of a raw socket' fill in the IP address and port number
Works for me.
Kees
07-09-2014 09:59 AM
I have this same problem. I tried your instructions and when I tried to "Validate" my connection, I got
"Could not open a VISA session to
"TCPIP0::192.168.000.002::1394::SOCKET".
VISA error code 0xBFFF0011
Insufficient location information or the device or resource is not present in the system"
I am using Windows 7 if that is an issue.
07-10-2014 08:33 AM
Can you ping the instrument and is 000 allowed in an IP address?
07-10-2014 01:25 PM
hi
i think there is no problem with the 0 in the ip address (on many local networks.. like mine, some PCs have 192.168.0.XXX !)
for my case, the 6221 worked from time to time (and sometimes just hung up... i can ping it for few minutes then it is blocked...I guess mine is broken (no useful asnwer from the Ke aka tektronix forums so I went back the the gpib)
regards
