05-23-2012 08:16 AM
Hallo every body
I would to use rs232 to connect my GPS module , actually I need to send configuration of GPS and receive the data using the same port, so what I start to do is to use the example for the labview (because I'm not so good to use labview) and there is error message appear(in the attachment) I couldn't find any solution for that ??? Any body can help me please
regards
Solved! Go to Solution.
05-23-2012 08:20 AM
I forgot to say I use USB to serial cable Cuase I don't have this port in my labtop
05-23-2012 09:36 AM
Did you do a search for that error code? Just install NI-VISA and that error will go away.
05-23-2012 10:57 AM
Thanks my friend it's solved actually I had installed NI serial but after installing NI visa as you recommend it's working without any error.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
