Error in serial connection (read & write)
Hallo every body
I would to use rs232 to connect my GPS module , actually I need to send configuration of GPS and receive the data using the same port, so what I start to do is to use the example for the labview (because I'm not so good to use labview) and there is error message appear(in the attachment) I couldn't find any solution for that ??? Any body can help me please
regards
(3,109 Views)
I forgot to say I use USB to serial cable Cuase I don't have this port in my labtop
(3,106 Views)
Accepted by topic author Alhaidar
Did you do a search for that error code? Just install NI-VISA and that error will go away.
(3,102 Views)
Thanks my friend it's solved actually I had installed NI serial but after installing NI visa as you recommend it's working without any error.
(3,090 Views)
