10-21-2016 02:00 PM
We are usning Windows Surface Pro 3 running Windows 81.
Software is LabVIEW 2013 service pack 1 version 13.0.1f2
The Surface is connected to a powered StarTech usb hub.
A NI USB-TC01 is connected to the hub
Our PIPS equipment is also connected to the hub via the ethernet connection
The NI USB-TC01 is used to take temperature reading from the PIPS
When the LabVIEW is launched and a temperature reading is attempted we get the following error.
LabVIEW: error connecting to GPIB driver of device.
It is necessary to us the usb hub because the Windows Surface only has one usb port and no ethernet ports.
Is there a problem using a usb hub with the NI USB-TC01? If so is there anyway to install the driver on the computer.
We have 4 of the Windows Surfaces and for some reason we haven't figured out, it works on one of them.
Anyone have any ideas?
10-21-2016 11:52 PM
10-24-2016 07:31 AM
We've had these devices for a while. I don't recall receiving a cd with drivers on it since the drivers are on the device itself.
I did flash one of the with the updates to see if that resovled the problem but it didn't.
10-24-2016 12:47 PM
