I am trying to get a Tenma 72-6630 programmable power supply to communicate through the supplied USB port/cable with labview. I tried the windows drivers but had no success. So I did some research on the NI site and found that I need to use the VISA driver wizard to construct drivers for this USB device. I then opened the manufacturer's driver and extracted the required information from there to input into the VISA driver wizard. The wizard finished without issue and I installed the new driver for this device. I told windows where to look for the driver and it found it no problem and installed it. However, this is where the problem arises....
I get a "This device cannot start. (Code 10)" through the device manager in windows. When I checked to see if LabVIEW could see the device using the VISA Interactive Control all I can see is the serial COM's and parallel LPT's but no USB devices appear at all.
I have tried uninstalling and reinstalling, rebooting, and modifying the VISA driver wizard driver with no success.
I am not sure what to try at this point and I am looking for suggestions....
I have attached the generated driver.
