I have exactly the problem described below when using a brand new Sony notebook (PCG-GRT40ZP) under windows XP, yet the GPIB card works fine on an earlier Sony laptop using identical software. Is this an unsolvable problem or is there still hope ?
Error Code 10 Returned on PCMCIA-GPIB Installation
Hardware: GPIB>>Plug-in Controllers>>PCMCIA-GPIB
Problem: Why do I receive the Windows Device Manager error Code 10: Device failed to start when I install my PCMCIA-GPIB card?
Solution: Code 10 is a Windows Device Manager error that occurs when a device is not working properly or is missing from the system. To resolve this error, try removing and reinserting the PCMCIA-GPIB card to make sure it is properly se
ated in the PCMCIA socket. If reinstalling the PCMCIA-GPIB still generates the error in the Device Manager, upgrade the BIOS of your computer to the latest version.
This Windows error code is generated if the computer BIOS does not correctly detect the PCMCIA-GPIB. BIOS updates are generally available from the computer manufacturer Web site. If both these steps fail, it is likely that either the PCMCIA socket or the PCMCIA card is malfunctioning. Install the PCMCIA card in a different computer to determine whether it is functioning. Contact National Instruments Technical Support (linked below) if these troubleshooting techniques do not resolve the issue.
