06-07-2017 07:00 AM
Hello All,
I am trying to use the examples provided in the Keithley library in LV 15. I am using ''Keithley 27XX Single Measurement'' for front and rear panel measurements. As far as the front panel is concerned I don't think there is any problem. But while using the rear panel with 7702 module I can only measure DC Voltages and nothing else (ACV, DCi,DCV,Resistance etc). Every time I try to measure some thing other than DC voltage I get an error message, error-221(Settings conflict). I am attaching the file too. Any kind of help is appreciated.
06-29-2017 06:59 AM
Hello Tshar16,
I am not sure, if I understand your question correctly.
Did you install the device driver for the Keithley 2700? http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=0470C9F181C02E75E0440003BA7CCD...
This driver should support your Keithley 2700.
Occurs this error using the Keithley 2700 or the Keithley 7702?
Best regards
Lucia
