Error -1073807346 in SR830
I am using SR830 driver provided in NI website.I have modified it to Serial Communication as the one provided is for GPIB.
When i run the examples with the change mentioned,i get the error in all the exapmles.
(4,518 Views)
You don't mention what you used for the resource name or how you entered it. You should be using drop-down menu to select from the valid resources that are listed in MAX.
(4,500 Views)
I meet the same problem like you.How do you solve this problem?
(2,921 Views)
