EMtest ERROR: File read problem
Also Befor the above commands
I will do the VDS200Q setup
Command :  MODL:SETUP:MOD <id>,<devmod>   // devmod = 1 FrameBUS ON (Autowave is master)
Command :  MODL:SETUP:IN1 <id>,<masterout>   // masterout= 0 Channel 1 of Autowave is connected to Analogue input of VDS)
Command :  MODL:SETUP:MOD <id>,<devmod>   // devmod = 2 Running mode(Autowave is master and signal goes out)
Message 11 of 12
(1,621 Views)
 I do not think the issue is with NI MAX or GPIB. You need to contact the vendor to make sure the commands you are sending are correct. Moreover, you need to verify that you are sending them in the right order.
Best of luck !
Regards
Suraj Pawar
AE, NI India
Message 12 of 12
(1,590 Views)
