05-25-2016 11:02 AM
When ever I connect the DG535 to Winspec, I get a Blue screen on my PC.
What does this indicate.?
San08
05-26-2016 10:40 AM
Hi San08,
Reading through your problem statement, it looks like you’re using a Digital Delay Generator created by Stanford Research, and you’re trying to integrate it with WinSpec spectroscopy software, published by Princeton Instruments. What NI software or hardware are you using in this system?
The Windows Blue Screen can be caused by any number of things, so in order to know what might have caused the one you’re seeing, we’ll need to know a little more about the situation that led up to the crash. What version of Windows are you using?
05-30-2016 10:21 AM - edited 05-30-2016 10:24 AM
I am just connecting the DG535 to the Computer that has WInspec version 2.5.8 through GPIB.
THe computer that has Winspec has Windows Xp version 2002
05-31-2016 09:58 AM
Hi San08,
Because you’re receiving a Blue Screen, my best guess is that the issue is somewhere in the drivers or software that you’re using. Because you’re connecting 3rd party hardware with 3rd party software, all we can do is work with you to verify that your GPIB cable is working, assuming you’re using our GPIB drivers.
Because of the complexity of the issue, if you would like to work with us to test your cable, I would recommend creating a Service Request. This would allow you to work directly with one of our engineers over the phone or by email, to narrow down whether the cable is the source of the issue. You’ll find the information you need about how to create a Service Request at ni.com/support.
Also, if you haven’t already, I would reach out to Princeton Instruments, the makers of Winspec, and let them know about the problem you’re running into. They may be familiar with the issue, and will be better equipped to help you troubleshoot how their software interacts with your system.
05-31-2016 10:03 AM
Hi Kathryn,
Thanks for the reply.
I had contacted Princeton Instrunments, they say that I need to update drivers of DG535.
I dont know from whom I should get the drivers.
Sang
05-31-2016 10:39 AM
Sang,
Because you're working with a 3rd party device, I can't tell you definitively where to get the drivers. I can tell you, however, that your best bet is going to be to ask the company that made the device- in this case, that's Stanford Research. If I were in your shoes, that would be my next step.
We do have drivers available for that device on our website, but those drivers are designed to allow you to use the instrument in LabVIEW or LabWindows/CVI, not in Winspec, so I don't think they are what you're looking for. I think, between talking to Princeton Instruments and Stanford Research, you should be able to come up with a solution for the issue you're seeing.
Good luck on your search!
05-31-2016 10:53 AM
ok got it.
Thanks for the information.
I will surely check with the Princeton Instruments or Standford Research Solutions
07-12-2018 05:40 PM
@KathrynTheGreatCan you please send us the driver for the delay generator DG 535
07-13-2018 08:14 AM
I don't Know the driver. But I use the technique LIBS. I need the delay generator DG 535. The detector ICCD (ANDOR Technology model DH 520-25F-03).
07-16-2018 08:20 AM
Linked below is the Standford Research DG535 driver.
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=2919
Misbah
NI Applications Engineer
