Driver for Agilent 34410A
I'm trying to connect to my Agilent 34410A through TCPIP but continously get error -1073807202. I am using Labview 2014 and just installed the drivers for the 34401A. I tried
Am I using proper syntax for my DMM address (IP = 192.168.100.123)? TCPIP0::192.168.100.123
I have also tried putting TCPIP0::192.168.100.123::INSTR as the web page for the DMM specified it would be that.
I'm not sure what to try next to be able to connect. I tried the attached example that came with the driver download and still see errors.
(3,489 Views)
did you check your device in Ni max?
if your max recognize your Agilent so problem came from your vi but if not
your device is not recognized for labview for several reason like mistake driver installation
(3,432 Views)
Is visa installed?
greetings from the Netherlands
(3,422 Views)
You can also open the command prompt then type:
ipconfig /all
This will display all of your network adapters along with their IP addresses and subnets by scrolling up.  A subnet is shown as a number like: 255.255.255.0 which for a given IP address of 192.168.100.3 would allow this network adapter to communicate with any adapter having a base address of 192.168.100 along with any final number 0-255.  Make sure that your network adapter is set to allow communication with your meter.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,385 Views)
