There isn't a instrument driver for this device on the Instrument Network library.
What you need to do is get the instrument's programmer's reference manual. You can then use the VISA I/O VIs to communicate with the instrument. Search for the documentation for any examples. Even if the examples are not VIs (most likely), they serve as a good reference on the sequence of commands needed for a particular operation.
Hope this provides you with a starting point.
DiegoF
National Instruments.
