Does GPIB-ENET/100 also use RARP?
Our existing UNIX network has several older GPIB-ENET devices which get their IP addresses from our server using RARP. We are going to add several new GPIB-ENET/100 devices. The Getting Started manual states that the new devices use DHCP to get their IP addresses.
My question: If we don't have DHCP enabled on our server, will the newer GPIB-ENET/100 devices "default" down to using RARP to get their addresses?
(3,044 Views)
Hi Tim,
Unfortunately, The ENET/100's do not support RARP. However, You can set the IP address of the ENET/100 statically. You could write down the addresses used by the current ENET boxes and configure the ENET/100's to those addresses.
DiegoF.
National Instruments.
(3,044 Views)
Thanks for your reply. Yes, our fallback plan is to use static IP addresses. We are going to have a mix of older units and new units at the same time in the system we are maintaining. I was hoping that the new units would use RARP such that all the units would work equivalently. I have since found that RARP and DHCP are quite different, so I will investigate configuring DHCP.
Using static IP addresses has several drawbacks for us. The units are located in remote areas which makes static programming difficult. If a unit fails and a spare unit has to be dropped in, it's much easier (with RARP) to just slap in the unit and update the /etc/ethers file. With a static address we'd have to make sure the unit is in programming mode and then set the static value
s. Not difficult for us, but the end users will need very exact procedures.
Based on how difficult DHCP is to configure/update/maintain we'll make a decision whether to use that or go with static addresses. Of course then we'll have to decide whether to switch the older devices over to static addresses for consistency, etc. That's progress for you!
(3,044 Views)
