Hey T.
You might want to run NI-SPY while you are running the MAX and LabVIEW application and look to see what the differences are. NI-SPY is very helpful in determining why one program works and another one doesn't. Just check the option to log to a file and then compare the two logs afterwards.
http://www.ni.com/support/gpib/max/nispy.htm
http://zone.ni.com/devzone/conceptd.nsf/webmain/C31BC5FB34DBC0EF86256ADF007B8A47?opendocument
JoshuaP
