06-09-2010 12:59 PM
04-15-2011 04:52 PM
Robert C,
This VI was tested using RS-232 port from a PC. It worked very well. This VI gets the current data values from three channels (CH1, CH2 and CH3) via ADC0 (command as torquimeter manual) and is stored in a string variable. The next step, separates the string in three numerical indicators.The commands must be uppercase. I hope have helped.
04-19-2011 03:05 PM
I would like to use this vi also. Can you save it in Version 9 and send to me. Thanks.
04-19-2011 03:29 PM
Ike,
Follow in attachment.
David
10-31-2014 02:51 AM
Hi
I am using the same vi which you have suggested and i have selected proper com port and other settings, but i am not getting any data,but if i send "ADC0" and "*IDN?\n" command alternatively then it is giving the data...but if i do that i will get zero and data alternatively.I want to get data without zero in between.. any solutions on why i have to send *IDN?\n?
11-03-2014 11:28 AM
Hi ELNO,
Do get more replies on your post, I would recommend starting a new forum question. Could you also please verify the device you are using? Thanks.
-Devon
11-17-2014 05:23 AM
Hi
Thank you very much for reply....
The issue is solved....."ADC0\n" command is working.
