Great to hear!
sorry i meant the driver not the dll. the driver i have downloaded, i have used and it works. but i want to write new code for my purpose using this driver and there i have stuck up
so the process is like following
it is called anodization of aluminium to prepare an oxide layer on Aluminium. It is done at constant voltage or constant current. So one sets the parameter and runs the instrument for required amount of time. Actually thats it, when explained in a simple way.
MY PROBLEM is
1) i want the voltage be set to a fixed value lets say 20V
2)After approx. 4 hours it should be decresed 0.1V/5min to 0.1V
3)Increase back to 20V in the similar fashion
all this through labview
As i am doing it of my own by trial and error, i came to the position of writing simplereader_serial.vi
I have attached this and the driver file
The simplereader_serial .vi is the code what i have written with the use of .vi´s from the TOELLNER (the zip file TOE8950-LT-V6.00.
hope this helps to give you some tips or much further
till next time
JP
