When i try to open the "DAQ assistant" in the block diagram, nothing happens, even if i click with the rigth button of the mouse and go to "properties" nothing happens. Everything else works fine. Thanks.
Has the DAQ Assistant already worked on your computer? In which circumstances does it happen ? Did you try to re-install the driver NI-DAQ ? Did you try to convert the DAQ Assistant ?
