09-17-2014 12:23 PM
Please help me to find out how to make the program behave well when one or both devices are not present
I am using the HP66XXA drivers.
09-17-2014 12:34 PM
If they respond to *IDN? , just check for that.
09-17-2014 01:58 PM
09-17-2014 02:19 PM
Thanks for your quick response.
When there are no devices connected the program shows
"Error 1073807195 occurred at hp66xxa Initialize With Options.vi"
"Posible reasons: Driver status Hex 0xBFFF00A5. "
"The interface type is valid, but the specified interface number is not configured."
If "continue" selected, The program keep repeating the message.But the initialize is not inside a loop.
The code is just a call to the HP5XXA initalize with the reset=FALSE and the request ID=FALSE.
09-17-2014 02:34 PM
09-18-2014 07:16 AM
I am using a GPIB-USB-HS Cable.
The power supply is a HP6675A (GPIB side). The computer is a EliteBook (USB side) with Windows 7 (64 bit)
Please let me know which driver you recommend and any brief example.
09-18-2014 07:48 AM
09-18-2014 11:18 AM
I am using the Continuous Measurement and Logging Template. Instructions step 1 Add hardware refnums
How to create/add the hardware refnums for the HP66XXA drivers ?
09-18-2014 01:07 PM
09-23-2014 02:48 PM
I hope you have some answers to help me to meet my deadlines.
I believe the (Continous) template for Labview 2013 is not limited to the DAQ devices.
Yes, I am using the hp66xxa (IVI driver). Or any other driver that works. Please let me know if you thing I should not use it.
I need more detailed information about how each driver works. The (hp66xxa do not have a help option)
Please explain in more detail how to create a hardware refnum.
It is not trival (At least not to me) that having the resource name explains how to create one.
Thanks!
