02-05-2014 08:24 AM
Hi !
I know that this topic is old, but I have now big difficulties to find the VBToolKit.
Moreover, I do not understand how to add DLLs on LabVIEW...
Thanks for help !
02-05-2014 09:11 AM
It has been quite a while since I solved this issue, but here's what I remember.
1. On the front panel, open the controls panel, and find Refnum > Automation Refnum.
2. Once the refnum is on the front panel, right click and select 'Select ActiveX Class' > Browse. This will give you a list of ALL available DLLs on your machine. If you search around you should find the OPUS DLL in the list. If it's not there, you might have to do some digging in the Program Manager to make sure OPUS installed correctly.
3. On the block diagram, drop in a Property Node (Functions Panel > Application > Property Node). Wire the refnum to the reference input of the property node.
4. Click the now active propery node for the list of all the possiblities.
I've attached a screenshot of a program that simply starts OPUS in the background. Once you get to this point, you'll be able to dig around on all the possibilities. I hope this helps.
02-05-2014 10:03 AM
Thanks a lot for your quick answer !
I can't find any opus.dll (there is OpusLabForm.dll, OpusFFT.dll, Opus2Vision.dll, Opus2FPA_u.dll, OpusMVC.dll, opusutil.dll, but nothing else).
Argh.
I would like to know if you could send me the VBToolkit mentioned earlier in the topic (since the link is dead and we don't have it in the opus folder on the install key). LV seems to not like when we try to add a DLL when browsing with the refnum automation, so will the opus dll work fine?
If it does not work, do you think we could acquire a spectra using LabVIEW with another method?
Thanks again !!
02-05-2014 10:17 AM
I personally have not tried it another way. You could write some VisualBasic code and link it into LabVIEW using ActiveX server. There are a truckload of examples on the web. You could try there.
I came across the attached pdf when searching for some VB to LabVIEW stuff I did during graduate school. Been a long time since I touched that, so you could start there.
I've found the VBToolkit, but it might be pretty old. After I ran the install .exe, OPUSCMD (v.3.3.4) appeared in my list of Type Libraries. I can't post it here, but I'll try to get it to you via Message.
02-12-2014 10:11 PM
Hi
I really need OPUS VBToolkit too. Would you please send me copy?
Much appreciate!
02-13-2014 06:36 AM
E-mail me: patrick.buckley at gtri dot gatech dot edu
02-13-2014 08:14 AM
02-14-2014 07:06 AM
02-23-2014 12:13 AM
Yes, I got it.
Very much appreciate!
04-23-2014 06:01 AM
Hiiiiiii...
Could you be kind enough to send me a copy of this OPUS VBToolkit. The link you gave seems dead. I wrote you an email too from gmail. I am running a pretty old version of labview (labview 6) to control the OPUS. Your help would be a bid lead to my work.
Shovon.
