06-29-2015 09:13 AM - edited 06-29-2015 09:37 AM
Hello everybody,
I would like to control a generator thanks to a control voltage. This last one would be sent to a switch wich turns on the generator.
To do that, I want to link the switch and the computer with a serial port RS232 by using NI-USN 232 cable.
I made some research on this subject and I am only a beginner on LabView but I would like to use one (or several) pin which will send 5V in voltage when I want.
Is that possible? Is there another way to make it?
Thanks in advance.
06-29-2015 09:55 AM
06-29-2015 10:02 AM
Thank you for your answer.
Maybe, I didn't explain myself correctly.
For example, on the Raspberry Pi, you can control a card by sending 3,3V signal with RS232 port (I made it last year so it makes a sense).
What I want to do here is to control an electronic card that turns on my generator after. I don't have enough to buy a generator controlled unless you know one not very expensive.
06-29-2015 10:40 AM
06-29-2015 11:07 AM
Thank you for your help.
I will try and see if it works.
07-03-2015 12:44 AM
If the control card is still to be developed, another option would be to use a RS232/TTL interface chip like these Maxim devices
07-03-2015 04:06 AM
The Maxim device is an interesting solution. Thank you.
But I think I found another solution : use an Arduino with Labview because it is compatible and I need several control voltages.
So it is not very expensive and easy to make.
I will tell you if it works.
