09-23-2014 05:53 PM
09-23-2014 06:10 PM
Yes, but the createFile function is one of the kernel32.dll. I just figured out while I was analysing a Visual C++ example:
Public Class Form1 ' Needed to create a handle to access the CP2104 <DllImport("kernel32.dll")> Private Shared Function _ CreateFile(ByVal lpFileName As String, _ ByVal dwDesiredAccess As Integer, ByVal dwShareMode As Integer, _ ByVal lpSecurityAttributes As Integer, ByVal dwCreationDisposition As Integer, _ ByVal dwFlagsAndAttributes As Integer, ByVal hTemplateFile As Integer) As Integer End Function ' Needed to close the handle <DllImport("kernel32.dll")> Private Shared Function _ CloseHandle(ByVal hObject As Integer) As Integer End Function ' For more information please check http://msdn.microsoft.com/en-us/library/windows/desktop/aa363858%28v=vs.85%29.aspx ' constants needed for "CreateFile" Public Const GENERIC_ALL As Integer = &H10000000 Public Const GENERIC_READ As Integer = &H80000000 Public Const GENERIC_WRITE As Integer = &H40000000 Public Const GENERIC_EXECUTE As Integer = &H20000000 Public Const OPEN_EXISTING As Integer = 3 Public Const FILE_SHARE_READ = &H1 Public Const FILE_SHARE_WRITE = &H2 Public Const FILE_ATTRIBUTE_NORMAL = &H80 Public Const FILE_FLAG_OVERLAPPED = &H40000000
I will try to implement this somehow into LabVIEW tomorrow 😉 Maybe it exists an easy way to call kernel32 functions?
09-23-2014 06:22 PM
09-25-2014 08:32 AM
Is it possible to open a COM-Port with VISA and create the COM-Handle (needed for the device-dll-functions) based on the "VISA resource name" instead of calling the kernel32.dll-function "createFile" (which is still not working)?
09-25-2014 10:23 AM
09-25-2014 10:40 AM
It is rather ironic that in saving about 20 Euros on purchasing the 4x relay board instead of the 8x relay with the serial port support, you are going through all of this hassle.
Here is an example about how to call kernel32.dll from LabVIEW. https://decibel.ni.com/content/docs/DOC-17820
You will having to do something very similar. The CreateFile function returns an integer.
You pass in string and a bunch of either integers or long integers. Look at the VB.NET example.
