Connect my Ohaus Scout Pro Scale to Labview without using the Print continuous setting
Hi there,
I am connecting my Ohaus Scout Pro Scale (Model 6001) to Labview.
My program can only read the data from the scale if I am in the print continuous mode or if I manually press the print button on the scale. But I only want to read measurements every 10 minutes and I don't want to press the button manually.
Therefore I implemented the VISA Write function and I am sending the command P\n (in \-comand). According to the Ohaus manuel this should be the same as pressing pring. But it doesn't work!!!
What am I doing wrong?
Is there someone else out there who is using Ohaus Scales and is able to directly read data from the scale?
Any help would be much appreciated! 🙂
(5,578 Views)
I can't look at the VI (posting from phone). Right click on the string control that you use for the command and make sure '\' Codes Display is selected.
(5,576 Views)
Check! I have the tick in the right place - '\' Codes Display
(5,572 Views)
Accepted by topic author staytuned
According to the manual, you send either a CR (\r) or a CRLF (\r\n). Sending just LF does not appear to be valid.
(5,568 Views)
yes - you are my hero!
I am glad to say that this was the solution to my problem! The comunication works now just fine!
 Maybe next time I can contribute something more substantual to the forum .:)
Thanks!
(5,537 Views)
