10-28-2014 09:41 AM
because it was not clear to me what it was that I had to do.
How would I create a CR constant?
10-28-2014 10:30 AM - edited 10-28-2014 10:32 AM
I already went to Visa Read/ byte count input/, changed Display format to hexa and wrote D in the constant box which is CR in Char.
but it still sees it as 13 numeric
what should I write in the byte count in order for Visa read to understand it should stop at CR?
something else:
hammamatsu receives instructions ending in CR
but does not send back 0D (cr), it only sends data without a termination character;
Request: 28.10.2014 17:24:35.22764 (+724.1494 seconds)
46 0D F.
Answer: 28.10.2014 17:24:35.32464 (+0.0970 seconds)
56 65 72 31 2E 36 30 20 43 39 35 32 35 2D 30 33 Ver1.60 C9525-03 FA0015
46 41 30 30 31 35 20 20
Port closed
Request ended in 0D
Answer ended in 20 which is space
Request: 28.10.2014 17:11:57.19864
52 0D R.
Answer: 28.10.2014 17:11:57.36664 (+0.1680 seconds)
00 00 0A 00 01 00 05 01 01 00 00 00 2D
answer ended in 2D which is - minus
So, if the read is waiting for CR it is not going to receive it.
How do you see this situation?
10-28-2014 10:35 AM
How do I make a button that, when pressed in the front panel, sends 460D toVisaWrite write buffer and 24 to the Visa REAd Byte count ?
10-28-2014 10:40 AM
10-29-2014 02:43 AM
I had already done that the instant you told me not to mess with Visa Serial and only work in the main block diagram.
Visa Serial has a constant set to True at its Enable Term.Char. input.
And thank you for telling me about "event structure" too, I am working on it right now.
10-29-2014 04:33 AM - edited 10-29-2014 04:36 AM
What function transforms the boolean 1 ,resulted from pressing the "Read value" trigger button in the front panel,
to decimal value 24
which I need to connect to Visa Read Byte count?
I need something that is triggered when receiving boolean 1 and Outputs the decimal 24.
Where do I find that object?
10-29-2014 04:59 AM
The above question still stands;
meanwhile I solved the 24 decimal input to visa read byte count by placing a constant ~24~ inside the event structure, tying it to the border and tying the border to the visa read byte count.
My first attempt had been unsuccessful because I simply dragged the constant into the event trigger rectangle and it did not work.
Now it does.
But still:
what object is triggered when receiving boolean 1 and Outputs the decimal 24.
10-29-2014 08:15 AM
10-29-2014 08:50 AM
The first event in the Event struct. is read info which has the command in the box and returns 24Bytes
the second is Quit/turn off remote which has the command in its box and receives 2 Bytes.
As shown in the picture, they work perfectly.
Now
I need to insert into another event command box a dynamic command such as the voltage regulation:
for that I created this prototype (in picture 2) which takes decimal values coming from the Numeric Control,
didides to 100, splits the quotient and the remainder, transforms them to hexa,concatenates them and adds V in front of the string and CR behind(this is the syntax Hamamatsu understand V value1x100+value 2).
I need to insert this command into an event.
To make it simpler: adjust the value from the knob, then click SET button and only then the value is sent to the event, thus making it simpler.
How do I insert the voltage command into an event structure?
10-29-2014 09:15 AM
