10-17-2014 06:54 AM
thank you!
did that: *idn\r
read operation
return count 4 bytes
BCBC
before, it was 2 bytes
BC
the error still stands: timeout expired before operation completed
10-17-2014 07:11 AM
10-17-2014 07:57 AM
the read device setting command is
R<CR>
the response can be
13bytes of data if the read is successful or
BC if failure.
Where can I enter these commands; for example, if I wanted to set the LCD off,
the command is: B<0h>CR
Where may I enter this command in order for it to be sent to the source?
the "select or enter command" drop down menu : how do I use it?
what does it do?
10-17-2014 08:13 AM
10-17-2014 08:17 AM
yes,in max
input/output, top right
below are
write query read clear
buttons
10-17-2014 09:32 AM
10-17-2014 12:59 PM
rigt now I am at home and I cannot connect the source.
On the test panel I have 4 large buttons:
configuration, input/output,advanced, NI i/o trace
on configuration submenu:
serial settings,flow control settings, i/o settings/view attributes.
on i/o settings:
write,query,read, clear
Where, on those menus, could I find a textbox that accepts commands(apart from the small window on the top-left with *idn\r )?
Regarding the driver:
-the one for the operating system is working properly;
-when I searched using Instrument Driver Finder I found an example called Hamamatsu C9525.
I opened it and tried to run it but it resulted in an error which was expected given the Max error.
Now I don't have with me the power source this weekend but I took the laptop with me home because I would really like to learn how to use NIMAX and Labview for control and acquisition, so I will try to install a webcam using MAX and control it in LabView.
Hopefully, by Monday, I will be more literate in Labview.
10-17-2014 01:12 PM
10-17-2014 02:22 PM
Alright:
So I'll delete the column of instructions and insert the ones which the HV source understands.
I can't wait for Monday to try this...
until then, I will try what I said: become familiar with LabView in controlling an actual device(as opposed to VI simulations).
Dennis, your patience and the quality of your advice have been outstanding!
Thank you very much for that !
10-20-2014 08:51 AM
Hello again!
in the manual, to set the high voltage output,
command: V<value1><value2><CR>
argument value 1: 0h~14h
value2: 0h-63h
response: success: VA
failure:BC,BA
Notes:
Input value1 and value2 in binary.
The range of value1 is from 0 to 20.
The range of value2 is from 0 to 99.
High voltage output = <value1> x 100 + <value2>
High voltage output is limited to maximum voltage or less.
As shown below, the command line can be also described in binary.
<56h><value1><value2><0Dh> ※hexadecimal representation
For example, in the case of Visual Basic, when you want to set the
high voltage output at 1000V, you can write as follows;
Dim Cmd
Cmd = “V” + Chr(10) + Chr(0) + Chr(13)
or
Dim Cmd(3) As Byte
Cmd(0) = 86 : Cmd(1) =10 : Cmd(2) = 0 : Cmd(3) = 13
I copyed and pasted
then
then
Dim Cmd
then
Dim Cmd(3) As Byte
into the selector enter command window, pressed write , pressed query
but the voltage setting remained unchanged at 0Volts
and I received:
1:write operation(cmd=\x93v\x94 + chr(10) + chr(0) + chr(13) )
return count: 38 bytes
2: read operation
return count 2 bytes
BC
how should I write this simple instruction in order to set the voltage?
what am I doing wrong?
