Connect M3-L Motor form new scale tech?
Hello my question is..
Have someone done a conection using this mothor, I would like to conect this motor by USB using VISA but the problem is that I do not know how because the VISA resource name do not recognice my device, I can ony use it with the software provided by new scale tech. I tryed to installa the drives using the NI driver wizard but the problem is thet I do not have the admin password so I can not.
(4,446 Views)
If it isn't a USBTMC device, you won't see it in NI-MAX.
if it isn't have the right drivers, you won't see it in NI-MAX as virtual COM port.
(4,434 Views)
The data sheet says the interface is i2c or spi. Do you have hardware for that. NI sells the USB-8451.
Attempting to use the VISA Wizard is just wrong.
(4,428 Views)
