Communication rs-232 using LabPython
I want to control and make a UI for a mass flow meter-controller using LabView but it appeared that I have to use some ASCII characters that are not supported in LabView or in browsers.
A colleague wrote me a script in python that send the command in the shape of  "chr(int)" instead of using ASCII.
For example: "Sinv2.000 + CRC + cr" is converted to "chr(83) + chr(105) + chr(110) + chr(118) + chr(50) + chr(46) + chr(48) + chr(48) + chr(48) + chr(143) + chr(85) + chr(13)" in python
Now I have to execute the script inside of a LabView VI, I use for this LabPython.
I tried to follow advices from different forums but it seems that my VI doesn't want to do the link between the controller and my script.
I have never used Python before thus the problem might come from the script.
-Leo
PS: I need to execute my VI on a computer that doesn't have LabiView nor Python. What should I install to make the executable works?
(3,226 Views)
You can use LabVIEW to convert ASCII Characters to ASCII Codes and Vice Versa : http://digital.ni.com/public.nsf/allkb/B9142E44E5363BAD86257441005A7454
Dasso
(3,188 Views)
