04-21-2015 04:30 AM
Hi
I am trying to communicate with my PSU through a serial cable from linux. I get connected with it, but i dont receive anything and when i try send commands to it, it just beeps.
Does anybody have experience with the TSX3510P PSU?
Best regards
Phillez
04-21-2015 06:53 AM
04-21-2015 07:05 AM
All i need is to read the current power consumption. I think i will implement this with python.
So far i have just opened the serial device with screen.
Do i need to configure the device with special parameters?
04-21-2015 08:02 AM
That would be in the manual that you should READ.
04-21-2015 08:20 AM
04-23-2015 02:09 AM
I have configured the serial port according to the manual:
www.*****.it.pt/Medidas/Data/Manuais & Tutoriais/07 - TTi Power Supply TSP3222/TSX-P Instruction Manual - Iss 12.pdf
I am using a NPort device to publish the RS232 signal to my network. When i open the device i can see that the RX light on the nport is on all the time and when i send some ascii characters to the device remote light turns on but i do not receive anything.
The manual states that when i turn on the device it is not addressable and therefore i should be able to control it "as a normal RS232 controllable device".
I have tried sending 04H (LNA) to lock non-addresable mode and this also does not return anything.
My goal is to be able to read out the power consumption during software tests of an embedded system.
04-23-2015 08:04 AM
