I have done this with several instruments. It is best to get a hold of the manual for this instrument and see what commands it uses.
MAX will not find this using the *IDN? query. In MAX, open the "Communicate With Instrument" window and type "ID?" (without the quotes), and hit query. You should get some basic information back from your instrument.
I use GPIB Read and GPIB Write most often. Your instrument probably doesn't support much else. Maybe Clear and Poll.
Be careful if you are using a newer, faster computer. There are Knowledge Bases and Discussion Forum topics that discuss the problems that can arise. To prevent these problems, I created my own Read and Write VIs. They just have a few milliseconds delay before the read or writ
e takes place
