08-10-2015 08:52 PM
08-11-2015 04:19 AM
Btw, I directly connected this USB-485 converter to a femle DB-9 connector with shorting pin 2 &3, shorting pin 4 & 8, shorting pin 5 & 9 and shorting pin 6 &7. I used Measurement and Automation Explorer to test this cable. However, it also shows writing has return count but reading has error. So does it mean that this USB-485 converter malfunctions or I made some mistake? How can I check that?
Will reinstallation of driver of USB-485 converter be helpful? Is this driver downloadable?
Thx a lot.
LW
08-13-2015 11:42 AM
You can try with reinstalling the driver, The link for downlowding it is
Link: http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/ssnav:drv/q/usb%20485/
