09-03-2015 05:36 PM
Hello community.I need to build VI that will collect torque data using a Mark-10 torque sensor. It connects to a PC via usb and collects data with a canned sw solution that is buggy. I would like to know how to do this better with Labview. What equipment would I need to interface/connect this sensor to a PC. See the address below for detailed desciptions of sensor and indicator. I'm not very experienced with Labview and any help would be appreciated. I have at my disposal NI 9236 and 9237 modules to work with. Is there any other recommended HW?
http://www.mark-10.com/instruments/indicators/3i.html
http://www.mark-10.com/instruments/sensor/series-R03.html
09-03-2015 06:16 PM - edited 09-03-2015 06:18 PM
What in their documentation makes you think that you using LabVIEW or NI-9236 or NI-9237 would be in the least bit compatible?
They have compatible software. Just use it.
09-03-2015 08:01 PM
09-04-2015 10:15 AM
Using the supplied VI/executable has been problematic. When the VI runs for a few hours it starts to miss data points and if there are any fluctuations in power to the lab it will crash. This VI is written in such a manner that after each scan it doesn't write to the data file....only after the alloted time the VI was set up to run. I mentioned the modules to just let the community know what I had at my disposal.
09-08-2015 03:29 PM
Can you provide a screenshot of the code you are using?
04-18-2017 04:43 PM - edited 04-18-2017 04:45 PM
There are 2 ways to do this. 1) Pull the analog signal off of the individual pins on the back and read the DC voltage with a NI DAQ. you'll need to do a calibration to convert the voltage signal into usable data. 2) you can pull the calibrated data out just by using VISA and a USB com port, no extra DAQ hardware needed. I've it for a number of Mark-10 devices. Parsing the serial stream is tricky (i'm only a casual user these days, and not very good at serial data nuances, however) - I've had issues with dropping data points because the parsing loses track if you change modes or something, but otherwise it's a stable read. you can set up the save however you like.
Their canned software IS definitely made in Labview (and buggy).
