I have a NI 485/2 card, and we are having trouble setting/keeping it with 8 data bits and 2 stop bits. If we run a short program (also with labview), using portmon we see an error message when setting the stop bits. If I use the advanced setting in the windows hardware port window, set it for 8 data bits and 2 stop bits and exit, when I go back in it has reset to 1 stop bit without having my having done anything else. However, if I set it for 7 data bits and 2 stop bits it seems to keep the values, and I can also then set it to 8 data bits and it appears to keep the two stop bits. However, when I then run the program, portmon again shows an error on setting the stop bits and when I look using the windows menu it has been reset to 1.
The program call nevertheless reports a success, and inquiring the state gives back 2 stop bits.
Any help would be appreciated.
Frans
