05-16-2017 12:03 AM
A few weeks ago I asked the question below and the answer is NO.
Can I use my USRP to produce desired wave in 1Mhz center frequency?
I have read some literatures about this filed and found that most ultrasonic communication systems are comprised of FPGA especially in MHz or higher frequency. Only part of systems use DSP or ARM besides FPGA.
It will spend a long time learning FPGA programming language(Verilog and VHDL) so I prepare to use Labview FPGA to simplify my work.
Here is my trouble. I have seen some Single Board RIO such as sbRIO-96XX products. Can Single Board RIO achieve my goal including producing signals in Mhz frequency, sampling and processing received signals?
Hope for your advice.
Thanks a lot!
Solved! Go to Solution.
05-22-2017 08:06 AM
you can refer to this documents for Single Board basic applications.
http://www.ni.com/singleboard/resources/
I'm not sure if single board RIO can generate signals cause it is a processing device not a function generator.
05-22-2017 08:52 AM
Thank you for your reply.
I found another method for my work and it seems more efficient and convenient.
By the way, now I think it can be applied as I wish above.
